Another vote for Bark River, I own a Rogue, Highland Special, Evo-1 and a Huntsman
The Huntsman is a super little big knife! Fits my hand like a glove, yet the thick and strong spine make this a tough little begger! At first I did not like this knife much, then I had the chance to try it out in the field and the performance was really good. The knife was able to perform most of the tasks I would normally use a larger knife for and easily out performed my folding knife (which I normally use for the close detail work). This is going to replace the need for a folder when camping for me.
The Rogue is a stunningly well made knife, the fit and finish are amazing and on a par with custom blades at 10 times the price. The grind lines and attention to detail are great. The wood pattern is simply stunning. I was concerned over the handle shape, as I have medium/small hands, but while the coffin handle is a real handful, the grip is very secure and this does lend a level of confidence that a razor sharp guardless knife demands!
The Evo-1 is a modified reproduction of the infamous Blackjack Mamba and is a super chopper in a very nicly ground and finished package. The Highland is quite simply one of the best light fixed blades I have used.
All these knives share several traits, however one that amazes is how the convex edge is so easy to touch up in the field. I use a belt and a little Flitz to get the edge razor sharp again. The A2 used and heat treated is almost an inteligent/magical steel! Hard when you need it to hold an edge and soft when you need to sharpen it. Not had any real concerns with rust or pitting either, which from a carbon steel is a real surprise.
I am a "bit" biased though, I am part of the Bark River Development Team as well as being a member of the BRKCA and I consider Mike a good friend of mine. However, that said, these knives flipping work and work well at an amazing price point. If they did not perform, I would not say they did!
