Bark River Strop Compounds
Hi all,
Currently I'm using and old belt for a two sided strop. I'm using black and green compounds bought at Sears. The black is on the rough side of the belt and the green on the smooth side...on a piece of pine.
I'm thinking about buying a strop with nicer leather...I prefer a large hand held strop and DLT offers a nice one at a reasonable cost IMO.
Who is using Bark River compounds and what do you think about them compared to big box offerings?
Thanks,
Kai
I find the black and white BRKT compounds work quite well. I don't use the green although I have a stick of it. I have four of the DLT double sided paddle strops. If you get a good one they are a good strop. But in my experience you never know what you'll get leather wise.
The white works very well on a hard wooden leather strop (DLT double sided paddle strops)
I use the white for maintaining my edges and after a sharpening
D2, 1095, and O1
I believe that you will find the Bark river compounds far superior to the "Big Box" store offerings.
Personally, I much prefer the Bark River CBN compounds though. A bit more expensive, but quite well worth the few extra dollars.
I have many strops but the one I prefer the most is from knives ship free. I use the bark river compounds and like them the most of everything I have tried. I used the black and white for a long time and only recently started using the new emulsions. I would start with the black and white - it should serve you well and last a ling time. I'm still on my first bars of each and have a long way to go on them before needing to buy again.
I prefer the black compound from Dico since it is much, much easier to apply. I do like the BRKT white compound though! For a mid range grit compound however don't ignore HeavyHanded's Sic compound which is also easy to apply and works on all steels!
Just cooked up another batch today! Did an experiment in aromatherapy and added some Fir needle essential oil to one of the slugs (have to test it). I don't think its going to do much for the experience, am not willing to add enough that it would be noticeable - small changes in component ratios can make a big difference...Will be pretty nice if it works.
