DETAILS: This is a very light weight machete with a black injection molded polypropylene grip and a nominal 18 tempered high carbon spring steel blade. Blade thickness is only 0.050, giving the B-18 a flexible spine.
Although the retail price is $5.88, I found it offered for the princely sum of $1.95 (plus s&h) here: www.michaelholigan.com/Search/AdvFind.asp?search_manuf_id=179
OUT OF THE BOX: (O.K., it comes in a plastic bag/sleeve, not a box). Considering the B-18s low cost, I was expecting to find some major flaw; instead I was impressed by its utilitarian quality. The blade has no warps and appears to have been machine sharpened; leaving the edge smooth and even, although well short of shaving sharp, with a full length wire edge. The first 2.5" of the blade foward of the handle is left unsharpened. The blade is thinly blued and coated with a clear tacky rust preventative of some sort. The handle has some molded-in coarse raised cross hatch checkering and a lanyard hole. There was a bit of excess polypropylene left on the mold seams, but this can be easily shaved off, if desired.
Since Barteaux advertises that their machetes come sharp - ready to use, I put it to the test, and did a bit of work with the factory edge. The B-18 was able to cut light/soft vegetation fairly easily, but the factory edge proved too dull for heavier/tougher stuff, like hardwood saplings and woody vines.
HANDLING & ERGONOMICS: I found the handle to be very comfortable and secure. The birds head on the handle makes it difficult for the machete to fly out of your grasp and the front of the grip is contoured to form a guard, that keeps your hand form sliding forward onto the sharpened edge (unlike the heavy duty Barteaux machetes, there is no D guard).
The balance point is 5.5 forward of the handle, but owing to the light/thin blade the B-18 dose not feel overly blade heavy and swings near effortlessly.
SHARPENING: I started with a file and moved onto a DMT hone. The steel of this machete seems to be harder than the M18 heavy duty Barteaux that I reviewed here: www.bladeforums.com/forums/showthread.php?s=&threadid=207783. The factory edge bevel was about 22 degrees per side, but I took it down to about 16 degrees per side, figuring that this would work better on the light vegetation that this machete seems best suited for.
TO CUT TO THE CHASE: After sharpening, the B-18 performed pretty much as expected, cutting lighter foliage with ease while proving to be a little light for things like thick vines and oak saplings; although these could be hacked through with out too much effort, provided that the blade was sharp.
I felt much less vibration through my hand/wrist/arm while using the B18 than I would have expected (I suspect that the flexible blade is dampening out some of the vibration).
The B-18s performance, handling, workman like quality and incredibly low price make it a quite a bargain in my opinion.
NOTE: I also ordered an E-22 Economy machete and a couple of canvas sheaths. The E-22 is similar to the B-18, the main difference being that the E-22 has a nominal 22 blade that is 0.065 thick. I have not had a chance to sharpen or use the E-22 as of yet.
The sheaths are made of light weight canvas and seem flimsy. There is very little to prevent the blade from poking or slicing through the sheath, and for this reason alone I would not recommend them.
Barteaux web site: www.machete.com.
Cold Steel Panga machete review:
http://www.bladeforums.com/forums/showthread.php?s=&threadid=217728
