- Sep 29, 2001
In lieu of a report on a new purchase, seeing as I'm flat broke, here's a little report on the Sanu BAS blem I purchased about six months ago.
I've found sharpening this knife pretty educational; nothing else I've sharpened has caused hairs to 'jump off' when brushed by the edge. After some work with the BAS, I've settled on a less sharp convex edge which seems less prone to damage.
The blade now carries two minor nicks and a slight warp in the belly, all caused while hacking apart half-dried hawthorn trees. It's performance was impressive when compared to both saw and machete. The edge has been straightened out as well as possible by cold-working it on my anvil. I considered retiring the blade, but it's so often the best tool for a cutting job. It's holding up perfectly.
The horn handle appears to be shrinking away from the butt cap, despite treatment with Hooflex. This would be a superglue fix, I suppose? The blade has some yellowish spots which I first assumed were sap which I had failed to clean adequately. Scrubbing has done nothing to remove the marks however, and I think I'm seeing a light patina. Between this and the scratches from work, I think I'll try repolishing the blade. My epoxy fix of the original chip out of the handle is holding up perfectly.
