- Feb 3, 2006
I wanted to start a thread where we could discuss basic and practical things to make while camping and backpacking to make life easier.
By basic I mean simple and takes little to no equipment. Think "a knife and a piece of string is all that's necessary" type of thing. I want to get away from specific gear. I want this to be more about what you can make instead of what you can carry. This could be something that you think is a no brainer that you do without even thinking but could be key to someone else starting out or who never tackled the problem in that way before.
By practical I mean something that makes sense for general camping and backpacking. Figure 4's and friction fires are cool but they're really not something most people are going to actually do every time they go out and unless you're in a survival scenario, really aren't necessary.
I'll start it off so you guys get a jist of what I'm thinking. When I camp I try to find a good fire stick for the campfire. Simple concept and really any semi strong stick will do but I've found that if you can find a stick with a branch coming off of it in a y it makes it easier to do two things. If the branch coming off is facing you it makes it much easier to hook logs and in turn makes them easier to move about the fire. Same concept as the hook on a modern fireplace poker. Also, if you need to pick up a log and place it somewhere else in the fire(carefully) you can use your hooked stick and a second stick to do so. With the hooked stick and a second stick you have 3 points of contact instead of two so you don't end up doing flaming stick juggling.
Any other simple bushcraft tricks you guys do when bumming about?
