- Jan 15, 2001
On You Tube I watched a fairly long video "Reconstruction of a Roof with 7,000 handcrafted slats obtained from the forest in 2021". It was in the Basque area and they were using the axes without a poll, and a fawn shaped tip of the axe handle. After cutting down a beech tree and sawing it into the appropriate lengths of the slats (shingles) they made all the slats only using a metal wedge for the first split an after that only the axe hitting it with a club made of wood. They did not use a froe as I have seen in almost all the other videos from Slovenia to Japan. They used the axe not only to split the slats, but also to adjust the thickness of the slats, trim the edges and remove the bark. After forming the slats, they stacked them like a chimney, so hollow in the center and left them outside over the Winter to season and then put them on the building the next Summer. Very skillful use of the axes. John
PS: Forgot to mention English sub-titles are available, until about the last few minutes when for some reason it switches to Basque/Spanish.
