Basque axes
Ugaldie
I will start a new Thread in this subject to talk about what I have leaned the last period. Be a bit patient with me, my time is very limited and my posts will be sporadic but I'll do my best.
First of all, we Basques have had centuries log axemaking tradition. Nowadays this is close to lose, in order to preserve the knowledge the last Basque axemaker in collaboration with local goverment have done two little videos about how have Basque axes have been produced traditionally. Here you have both, enjoy them,
[video=youtube;KHgCqtxjYz0]https://www.youtube.com/watch?v=KHgCqtxjYz0&feature=youtu.be[/video]
[video=youtube;Q5i0uSjh6Bk]https://www.youtube.com/watch?v=Q5i0uSjh6Bk&feature=youtu.be[/video]
I watched both those here - very cool and quite interesting. :thumbup:
Thank you for sharing those Ugaldie. I suppose like just America, all the traditions get swept away with changes in culture and technology.
That father and son are a rare breed.
Thanks for these videos. Very informative.
I find myself freezing the video every few seconds to read all the text.
Notes as I watch the video:
The handle makers plane is too fresh, too new. He only used that for the video. His everyday plane would not look like that. I bet he has an apprentice.
F114 is the equivalent of C45 - a medium carbon steel but easily capable of reaching mid-50s HRC while retaining toughness. It wouldn't be what we'd call premium but it would be very good.
That blacksmith knows his work well. No wasted blows at the anvil or the power hammer.
Surprised to see him stoke the coal while hot steel is on the anvil. But he knows how much time he has.
He gives a great explanation of reaching forge welding temperature.
He uses the word 'head' to mean 'eye'.
That steel handle makes one helluva drift.
He's not going to have to do a lot of grinding - mark of a good smith.
What he calls 'iron' is what we would call mild steel.
He should wear a dust mask for grinding. There might be some 'caffeine-o-vision' going on - video sped up.
Good description of drawing colors. He doesn't need those temper color charts (he already knows his colors) but it's nice that he showed them to us.
I wouldn't have thought the hafts would be pneumatically seated but it makes sense.
Great video. I hope he gets an apprentice.
Thanks for sharing this.
Great videos thanks.
It would be great if the internet axeboner could point there & make the Basque tools a known thing like the Swedes became.
We need US distribution!
Love these axes!
Enrique is very inspiring.
These axes from Hachas Artesanas Jauregi are listed as 1.50kg and 2.00kg. Just to clarify, is this head weight or total weight?
Thanks
Thanks
I think it's the head weight. I have the 2kg, and the haft is thin and light because it has to slip through the eye. I'm still agnostic on these axes. The heads are beautifully finished and the edge seems to hold up. But the hafts are so thin and light and short that it feels a little uncomfortable to use, especially when the head is always just a wee bit loose.
You pretty much have to use these on your knees, unless you're chopping something waist high. I was out splitting some maple, switching off between a full-sized Collins 5 pound axe and the Hachas Artesanas Jauregi. The weight of the Collins gave it an advantage, but even when I was on my knees chopping small starter pieces inside my low woodshed, the Collins was more effective.
I have a 6-inch alder that needs to come down because it's about to start shading my solar panels, and I'm going to try the Basque axe on that. I get the sense that it might do pretty well with that big head and the 26-inch haft, but I don't yet know.
Thanks Twindog. I actually ordered the 2kg Hachas Artesanas Jauregi today and saw it only has a 26'' haft. I don't think it would be very hard to made a new one maybe 30 or 32 inches and have the ability to change between them. Although I have read that the factory haft is put on with a press, so may be difficult to remove.
My head came loose, although easy to tighten up by dropping the axe on the top of the haft. I have it soaking in boiled linseed oil to see if that tightens it up. The haft was unfinished when I got it.
It's difficult to make a nice, round comfortable haft because it has to slip through the eye of the head. So the haft is thin and flatter than normal American axes. It may be possible to craft a typical wedged haft, but I don't know what issues might come up. Seems like it would be easy to do.
You can hang slip-fit heads on conventional handles but it generally takes a cross-wedge or two to properly fill the eye.
Thank you for your comments! There is a lot to comment, let's see if I have enough time.
I'mSoSharp those heads look like old Biscayne pattern. From the end of the 1500's Basques were not the only makers of this pattern, lookingbto their eye shape there is a fair probability for them to be Basque made, that's all I can say.
Square_peg I have contacted the maker severall times and I have said them to fix the subtitles problem, they allways say they are working in it...
The handle maker worked single, he has retired more or less a moth ago. That's a pity he is a very good wod reader. At the beginning of the video they say they are not showing how do they actually produce axes but how were they traditionally produced. The handlemaker used electric powered tools for his job.
F114 is the same as C45 or 1045, the steel is not stellar per se but the axemaker has the heat treatment totally controlled, ask me about it if you want to know more. I own a 2,2Kg Jauregi Basque axe with 14° bit in 1045 steel and it cuts black lockust flawlessly.
Using head instead of the eye is due to the form we have to talk about each part of the axe in Euskera. For example we literally say to "round the head" to give form to the eye.
That steel handle is not a handle but the piece he uses to give to the eye the tapered oval form.
The Basques (mosty old timers) when we talk between us we use the term iron to refer to all kind of iron alloy. This way to refer to the steel is found everywere from antique documents to modern steel mills. We use the correct term in foreigner languages.
He doesn't use masks while grinding, he has admited me that is a bad habit. That grinding speed is his working speed, indeed I have seen him working faster. That man is a master and a pleasure to see working.
I agree you Lieblad, these axes have a huge history and they are unknown for the usual axe fan.
Slim278 that is the total weight.
Twindog it's allways weird when you try axes made with other phylosophies. We who are used to Basque handles found the roundish American type handles awkward. The flat side of the handle gives the user quite precise information about the orientation of the head, loosin that information in echange for nothing is weird.
These axes have allways had his type of handles and there have been few places in the world who have seen the amount of axe usage our land has seen. I have never seen a person using these axes in his knees, use them as other axes don't leave your fears ruin your axemanship.
You can never compare an axe cutting the same log from different heights, he one you use standing will allways win to the one you use in your knees.
There is not any problem if the head of these axes gets loose, the easiest way to tighten it is to use it,
[video]https://youtu.be/ImBQCe1snO4[/video]
I have listened the "unfinished handle" complain severall times, the handle is finished the way has allways been finished. The smoothnes of the handle is a fault in itself, the grip is defective specially when you start sweating. You will never see a Basque axeman painting his axe handles with chalk as I have seen Australians do. We have a very different handle culture, we prefer good in hand performance rather than durability.
You can wedge a local standard handle to a Basque axe,
15325234_1223600101010190_8749557543878506755_o.jp  g
If you want to try wedged handles I encourage you to use the handles Basque competition axemen do use.
I ordered the 2Kg and like it very much. Could use a little longer haft, at 25'' is not what I am accustomed to. I do plan on getting a smaller one and noticed Lamnia just got a new shipment in stock.
They have a stainless version advertised for butcher work. I wonder how that would work against trees. http://www.hachasartesanas.com/
Slim278 if you live inEurope contact directly the maker, you will get your axe much cheaper, you can also ask him to customize your axe to your woody needs, he doesn't charge you more money for it.
The stainless steel is not as tough as the normal one. Sometimes customers ask him to produce stainless axes to use them in the wood and they have never had any problem with their axes. But my opinion is to use carbon or tool steels for these tasks.
Does he speak English?
