Batangas Original Balisong
Clay
Balisong forum Moderator
I got one today from KnifeZilla.com, and to be honest I'm quite impressed. I've never been known to be a fan of Philipine made Balis. This one however isn't too bad. Maybe the Filipinos are finally getting their act together.
Heres my review (if anyone is interested):
~This is by far the heaviest "non-skeleton handled" knife I've ever played with, equal to my BM 45S. Nice fat handles too (I love that).
~The fit of the inserts into the brass handles is flawless (not a gap in sight!). A first for any Philipine Bali I've seen.
~Overall length open is 11 1/4". Large.
~The Blade is thick, double the width of my BM 45S at the spine, and is pretty sharp. There are no markings at all on the blade,
so I'm not positive of the steel type. Knifezilla says only "high carbon". Downside is, theres no KICK area, so that sharp blade may not stay that way for long.
~Balance point closed is dead center. Open, is an inch and a half below the PINs. Right where I like it.
~I worked this Bali hard for a good half an hour and...... THE PINS DIDN'T BREAK(inserts are still tight too). Whoo Hoooooooooo!!!!!
All in all, I wouldn't use it as an everyday carry knife, mostly because of it's size, but it is a beautiful example of a Philipino Balisong. Perfect for the collection.....
I think it's a Keeper!
Clay G.
www.balisongxtreme.com
Hey Clay-Thanks for the review.As soon as I log off the forums I'm going to their site.I was unaware Philipine made balisongs were available again from commercial sources.When I was more active in buying them I found a huge range in quality. Sometimes I would see a gem but more often lower quality ones. Also all were very stiff and had to be loosened up but were fragile so you risked breaking them.
Maybe they looked at samples from other sources and are getting their act together.
Tim
Hey Clay,
Does that bali have a latch? It doesn't look like it.
Clay, glad you liked it.
There's only a limited number of them at Knifezilla, and they're going fast, too..
Dan
I know I can't carry these, but is there any legal repercussion to having them delivered to California?
Also, what do you think of the Jaguar line at the same site?
Support RKBA Advertising!!!
http://www.citizensofamerica.org
Timdennis- The handles arrived just fine, not tight at all.
CYA- Yup, there is definitly a latch.
Ewok- I know of people that received them in California, give it a try. As for the Jaguars, the only model I like by them is the Silver Skeleton handled model. The only problem is the PINs...... very lame. If you can fix them yourself though they're worth it. If you need help fixing them, check here:
http://www.balisongxtreme.com/baliplanet2/tips/7-18-99.htm
Clay G.
