but what about the soak differences?
I guess that depends on what steels you are using and how long of a soak you need. I use simple steels (1080/15N20) so my answer might not be applicable, but when I've had more than 2 or 3 blades to do, I'll put in 2, then when I take one out to quench, I'll put another one in.
What I do is open the door, take out the blade, close the door while putting the blade in the oil, after 6 seconds, take the blade out and put it in the aluminum quench plates, then put the next blade in, and repeat when the blade in the quench plates is cool enough to remove without gloves.
What about decarburization?
I've recently been using an anti-scale coating (ATP-641) and this really helps to minimize decarb. But, IMO, this is only something to worry about if you are forging your blades and bevels close to final dimensions. Doing a quick google-fu search I found a research paper that estimated decarb depth from 800C to be 0.35mm or 0.013" (
https://www.forging.org/uploaded/content/members/public/PDF/Role of Stable Carbide Formers on Decarburization Depth.pdf), which would be removed during most post HT grinding.
One thing to note, in the study above, their procedure was to have each sample soak for 2 hours,
much longer than what we knifemakers do, so decarb should not be as deep in practice.
