BBQ Firestarters VS ESBIT tablets: Non-ideal firemaking
Hello all,
I did some research but I couldn't finde any direct comparison between the generic (cheap) break-to-size BBQ fire starting tablets and ESBIT tablets (looking at the 14gr ones).
My activities take me 95% of the time above the treeline, so firemaking is not a concern as I always carry stoves for cooking purposes. BUT last weekend I went with my daughter to a free mountain cabin in a relatively low mountain (1500m). I had a MSR Windburner with a full cannister of gas for cooking.
I left my daugther at the cabin with two other hikers (young Erasmus students, french and german, btw) and went back to gather wood. It was snowing ligthly and it had been raining. As per BF standards, I tried to stick to dead standing timber.
Once back at the cabin, I cut it into manageable sizes for the fire place, split some of the logs (5" or so at most), etc. There was some kindling already there, but likely gathered by the Erasums students, so it was also wet AND green.
To put it mildly... we had a hard time starting the fire. I left half a lung there, that's for sure. I must say I used all the ticks I had read here such as feather sticks, getting the inner core of the logs, etc.
Which lead me to think that I could have done much better with some fire starting tablets.
So, after all this introduction, here are my concerns. BBQ Tablets usually come in big blocks that you need to cut to size and I don't want to carry a whole block during my outings. Also, I recall from past experiences, that even if you wrap them well .. they tend to evaporate over time. Besides, tThe don't last too long once lit.
On the other hand, ESBIT tables have a different composition (HEXAMINE, I think), are individually wrapped and are supposed to last for 12 minutes (14gr tablets).
I don't want DIY solutions, nor am I worried about the tablets not catching sparks from a ferro rod, etc... I always carry several ligthters and we are talking about convenience here.
What are your thoughts? Are the ESBIT tablets worth it as fire starting?
Mikel
I have never tried them for firestarting. I always use cotton balls soaked with vaseline for that purpose, and they work very well.
You can get offbrand heximine tablets.
You can get indivually wrapped fire starters.
I recently bought a box of fatwood
It all kind of works.
Just get what is most convenient.
The soaked cotton balls seem to be popular arround here. Might give them a try. But I somehow thought they tablets could be somewhat more reliable. Thanks!
I saw some unknown tablets when searching in Amazon (a lot cheaper). But since they don't list the composotion so I bought Esbit.
Could you point me in any other (cheaper) direction?
Thanks!
Mikel
I have found the vaseline soaked cotton balls to be 100% reliable. Make sure they are real cotton, not polyester. Rub a dollop of vaseline into the cotton ball. They can be pressed into a small container. When you are lighting the fire, pull one into two halves with a lot of fibers extending out. It will catch the spark from a firesteel very easily, and burns for about 30-45 seconds. These are a very inexpensive firestarter.
Thanks!
Mikel
Sorry I am Australian sort mostly doesn't help.
Samba is generally what i use.
Well, seems that I had a mishap while online shopping and I will end up with not one, or two... not even three... but FOUR (4) packages of ESBIT tablets (12x14gr).
So seems I will have plenty of oportunities to try the real deal and see if they work as expected.
I will keep yo posted!
Mikel
The BBQ blocks will age out, and off-gas their fuel over time, I've seen it damage other gear.
Wetfire tinder cubes work very well, but again they do age out if the wrapper gets punctured. The Tinder Quick are basically a cotton braid cord soaked in a light wax, they are also very good, and I found very stable long term. I like wax over anything else because I deal with heat, and mix down the raw parafin with petroleum jelly so that it takes a spark better, but a big candle makes a good fire starter if you know you will always have matches or a lighter.
Exactly my thoughts regarding BBQ blocks! I experienced that first hand. I also noticed the ESBIT packaging is a bit flimsy in the underside and might tear easily when stashed with other items. Might place a piece of duct tape over the aluminium... just in case.
The candle is a good idea as well. Usually in these free cabins people carry candles to provide ambient light. Head torches are not ideal for a chill chat arround dinner as you are blinding everyone you look at! I always have plenty of ligthers, so that's not a problem!
Mikel
