- Oct 18, 2001
Canvas micarta is probably the toughest synthetic material available to knifemakers. It is dense, hard, resistance to warping/moving, stable, resistant to water and so on.
However, it is not by any means "maintenance free".
If you have a canvas micarta handle - it DOES benefit from a "mineral oil bath" once a year. Helps keep the micarta from drying out and is a must for daily usage/carry (unless you're in the tropics....
Here's what mineral oil looks like:
And here's a Wiki about it:
http://en.wikipedia.org/wiki/Mineral_oil
You can get it anywhere there is a pharmacy - Walmart included. It is CHEAP (a dollar or so) and easy to use.
Plus it is FOOD SAFE. :thumbup:
Another substitute that is easy to get = WD-40
(but it's not food safe)
Take a look at this picture:
3 Knives - all in natural canvas micarta that has been bead-blasted for texture.
3 different levels of handle finish
If your knife looks like the one on the right - it is dry and needs some oil.
The knife in the center has just been "dipped" and has a fresh coat.
The knife to the left is what your handle should look like a few days after several dips in the oil - to let it soak in (it's just slightly darker).
Canvas micarta will darken slightly with time - especially true if it has been bead-blasted....and even moreso with natural canvas micarta (will eventually turn yellow-brown).
So, keep those handles oiled and not only will you have a great finish on your knife, but the handle will last longer too.
Any other care/maintenance comments?
Dan
Dan
