Well, as I hear it, the older Busse blades are just bead blasted, which opens up the pores on a blade and gives dirt and moisture a place to accumulate and cause rust and corrosion. The current method as I understand it is to blast the surface with a course grit and then a second blast is done with glass beads of some sort that serve to peen the opened pores closed. So you get a non glare finish with nearly the rust resistance of the satin finish. I have had some of my Double Cut Bead Blasted (DCBB)blades, that I have carried against my skin during sweaty Illinois summer months, rust a little. The rust usually occurs on the butt end that is in near constant contact with me.
