- Mar 22, 2001
Help! I'm trying my hand at bead blasting, but things are not going well. So far, I have not even been able to take the shine off Micarta by blasting. It seems that I'm not getting enough velocity behind the abrasive.
I got one of the Harbor Freight two door cabinets, a compressor, and 80 grit glass beads. The cabinet specifies 5 cfm at 100 psi, while my compressor (10 gallon) is only 4cfm at 90 psi, so I realize it's a bit small. I didn't think that would be much of a problem, as I've read in previous threads about guys doing small blasting jobs with the small pancake compressors, and I'm only thinking of doing one blade and a pair of liners at a time.
I thought the problem might be the small self-coiling air line, so I picked up a larger line from Harbor Freight. Thinking it might also be the gun the cabinet came with, I also picked up one of their cheap gravity feed hopper guns - I saw Peter Atwood use one of these to good effect in his video. Still no good.
I SEEM to be getting good pressure out of the compressor when it's not hooked up to the blast unit, but that's subjective - I've never owned a compressor before. Is there a way to test the PSI, maybe?
I've checked for air leaks between the compressor and the blast unit. There are none.
Any advice you could give me would be greatly appreciated.
Thanks!
Thanks!
