Bead blasting media
I have been reading about using a bead blaster for straightening blades. As I make a lot of aeb-l kitchen knives I want to give this a shot. For anyone who has tried this, do you have a recommend coarseness. I see ultra fine, fine medium fine, medium coarse and very coarse and am not sure which is best. I assume it gets finer over time as well but it won't be do a whole lot. I may also texture some handles with it.
You blast the inside of the curve. The dimples from the blasting creates divots which stretches the metal on the inside of the curve and straightens the blade out. At least I'm told anyways. Sounds like a much safer way then heat and bending the blae with force.
It's the same principle as using a peening hammer with a carbide or tungsten bit.
I've heard that too, but never tried it, but wouldn't you have to only leave one side blasted for it to remain straight? Otherwise the peening would be removed with hand sanding
The "peening" by shotblasting is less about the surface deformation than it is about localized stress relief. Once the stress is relieved, the surface can be sanded without reintroducing new stress.
All bets are off if you go back to the grinder and warm it up.
