Bead blasting has gotten a bad name from the years past. Lets break it down.
Sand blasting is done with sand. This hides all kinds of flaws.
Aluminum oxide blasting does about the same thing .
Glass beading the same thing after it is cycled a few times.
All of the above cuts the metal and leaves open pours.
Ceramic Peening is a different case.
This closes the pours. YOU CANNOT hide anything.
The blades have to be finished to a 400 grit finish or the grind lines will show.
There is a difference.
Thanks to KIT CARSON many makers are ceramic peening now. I like the finish very much.
Ceramic peening is small round ceramic balls.
It leaves small dimples like shot peening instead of cuts as the sand, glass and AO does.
Ceramic peening is a plus!
Web Site At
www.darrelralph.com
MADD MAXX !
