you might get by with the D2 with just a bit of oil where it has Cr in it but O1 you'll have more of a problem with it.sinawalli said:I use tool steel to make my knives. If I were to bead blast a finish on D2, or 01, would that cause it to be even more prone to corrosion, due to pitting? Has anyone tried this? Thank you.
If you are bead blasting consider brownells ospho blue ( cold treatment).sinawalli said:I use tool steel to make my knives. If I were to bead blast a finish on D2, or 01, would that cause it to be even more prone to corrosion, due to pitting? Has anyone tried this? Thank you.
