- Oct 28, 2018
Does anyone know of a set of bearings that would fit a Benchmade Anthem that would be better than the original ones?
The ball bearings themselves don't move as freely as they should due to the cutout being to tight, I'm just looking for a set that doesn't have this issueBetter how, smoothness or corrosion resistance? Most everything is a tradeoff.
I've read about a few that have swapped washers in place of bearing. Those are better in some ways.
Yes I've taken it apart and measured it, unfortunately he doesn't make any that will fitDo you have a caliper to measure the bearing? You can most likely get something from Skiff made blades. Their bearings are the best and they have multiple options. The anthem is most likely a 3/16 pivot.
https://www.skiffmadeblades.com/col...earing-1-16-in-11-ball?variant=20773681791065
0.0500" with a 1/4" pivotWhat's the size of the Anthem bearings?
Yes, I removed it to measure it.I think you're measuring the disk. Did you measure the actual ball?
Yes, unfortunately the anthem bearings are a non standard size so most suppliers don't carry themHave you checked here?
