Back to the Becker! I had quite a few orders to fulfill in the last few weeks so I have been limiting time on the BK2 but it just sold ...so time to crank it up!
CNC/3D primer: I have had a few folks show interest in the Becker scales with shell inlay work. Since I need to create a wooden scale before I can inlay AND I love the feel of the factory scales I decided "why change what works?" and went full ahead with creating a
3D model of the original for the CNC machine. 3D work (including 3D printing and CNC) can be faster in terms of actual cut time but often require a substantial amount of work, design and programming before a cut can even begin. We use the CNC for very specific parts of instrument building process, mostly to build the patterns, jigs and fixtures or for those tasks which have been calculated to benefit the most from the use of the CNC as the main tool. Truth be told you could easily cut and shape a large number of knife scales by hand in the amount of time required to program this single model ...the decision to take a part or design to be milled on the CNC machine is all about efficiency and you have to consider the programming time into your planning. For me this design work will make it much more efficient for me to make scales in a number of different materials, experimenting with wood types and if desired modifying scale design (in the future). In short, I don't recommend this approach to make a small number of scales!
Process:We don't have 3D laser scanning availability at the shop yet so I went to a surface probing technique native to the Shopbot platform. The probe (shown below) moves incrementally along the X and Y axes "looking" for the edges and surface of the object being scanned. When the tip of the probe touches something it closes an optical contact and the machine records the position. The probe then moves along until it contacts the surface again. After the probe has covered the entire object (which took about 4 hrs on this scale) the computer creates a 3D surface by connecting all of the points in a 3D skin, or a web of points.
When the 3D scan is complete the rough 3D model is ready for trimming and smoothing. Unfortunately I didn't snap a pic of the rough 3D skin
but the probing gets the base of the CNC machine (spoil board) and can be quite noisy so the surface is really bumpy. I do something very specific inside of the scale for the middle scale fastener (maybe more on this in another post) so I don't need a hole cut all the way through. In the 3D software I removed that hole and created clean paths for the other holes and counter sink platforms.
Here is the finished prototype model. Today, I should get to cutting a few scales out of pine or other scraps and inspecting the positions of key components. If need be i will make adjustments to the 3D model and cut again. Once the model is correct I will cut some out of the hard woods. The idea is to get the holes and profile correct, the final shape will be finished by hand.
I will post some pics of the first test scales when I get them cut!
