Becker BK7 sheath question
stringer99
Banned
Hi. I was looking to put together a survival knife and zeroed in on the becker BK7. Does any1 know the inside dimentions of the pocket(s) on the becker sheath? I want to fill it with a number of things, but fire & sharpening stone are a must. So far i was going to get a sparklite and swedish steel but does any1 know what would be a good stone for the becker AND would fit in the sheath with these items? Or any other suggestions concerning this would be much appreciated. Thanx! :cool:
You can easily fit one of the Altoids Tins (about 3 3/4" long by 2 1/2" wide by 3/4" deep) inside the pouch. These make great little pocket survival kits. I have a Spec-Ops Survival sheath ordered and on the way. I just recently made a new PSK housed in an Otterbox 1000. I'm hoping that it will fit in the Survival Sheath pouch. I hope that helps. Let me know if you have any more questions. :)
Soup
Here's the original kit that I put together. Since then, I've added a BSA Hotspark, LED light, parachute shroud line and an industrial grade 55gal. drum liner to the sheath. :D
Here's the contents and locations of my BK-7 Kit. I just had it out this past week for 48 hours in the bush and gave it a field test.
HANDLE CONTENTS – The handle scales of the knife can be removed to reveal two small hollow cavities. These are removed with a small hex-wrench and filled with a fishing/trapping kit: line, sinkers, hooks, wire.
SHEATH CONTENTS – The sheath has a pouch that fits an Altoids tin and there is room below it to attach items with a rubber sleeve. Paracord is attached to the leg tie at bottom of the sheath and the wrist lanyard hole on the handle of the knife.
KNIFE SHARPENER
- US Army ceramic stone, Tied on, rides under velcro strap on top of Altoids tin
FIRE – The kit has both tinder and an initiator that are impervious to the elements.
- Sparklite fire starter, tin
- Sparklite tinder, 2 tin
- Straw of treated cotton
- Strike anywhere matches, waterproof, 4, tin
- Candle, 3, tin
- Rubber ranger bands, excellent fire-starters, various locations
WATER – The knife contains both a water container and treatment method.
- 5 liter galão de Emergêcia, rolled tightly under rubber sleeve below pouch
- Potassium Permanganate, tin
SHELTER – The shelter provisions are intended to make the construction of an expedient shelter easier, not necessarily to compose a shelter. There are three components, water/wind proofing, heat proofing, and cordage. In practicality only a space blanket will fit on the sheath, attached by ranger bands below the pouch. The space blanket is waterproof/windproof and will trap body heat. The duct tape is used to seal leaks and join seams. The space blanket and rolled water carrier is no more bulky than the pouch and Altoids tin above them.
- Space Blanket, under rubber sleeve
- Para cord, 7 strand, 2 meters attached as leg tie
- Duct tape, 1 meter, wrapped around space blanket
- Heavy needle and #4 waxed line for clothing repairs, tin
SIGNAL
- Starflash mirror, behind tin in pouch
- ACR Whistle, under rubber sleeve on back of sheath
- Inova Night Vision Red LED light, tin on braided neck cord
- Other signal methods include space blanket as reflector/marker, and fire/smoke
- Night signal reflector on back of medallion compass
NAVIGATION
- Medallion type liquid filled compass with braided #4 waxed-line neck cord, tin
LIGHT
- LED light
- Candle
MEDICAL
- 4 square inches Moleskin, inside bottom of tin
- 10 Ibuprophen, tin
- Salt, tin
- Sterile Scalpel Blade, tin
- Single edge razor blade, tin
Braided neck cord – The compass, Inova LED, ACR whistle, and Starflash mirror are to be attached to the neck cord and worn around the neck at all times during a survival situation. This leaves the compass readily available for navigation. It also leaves the day/night signal capability instantly accessible during the emergency.
Go to Ron Hood's site at www.survival.com. He ran a "contest" for the best Becker size kit. Some smart folks had some good ideas.
Wow thanx for all the great ideas. :)
randjack i dont see anything like that on that site. its impossible to navigate thru and the search doesnt work. what did they come up with?
