- Dec 20, 2012
Help, I can not get them sharp n even purchased a ken onion work sharp, the medium belts do great but fine grits dull again.
sounds like you're rolling the belt over the edge. is that possible?
What angles are you using?
For starters what Beckers are you trying to sharpen? Next they come from the factory with an approx 20dps edge, to sharpen em at 15 dps your going to need to spend some time on the course belt reprofiling the edge until you reach the apex. Try coloring the edge with a sharpie so you can see when your hitting the apex. Do the same number of passes per side, and don't progress to a finer belt until you've reached a bur on each side.Set the guide to 15 though I dont fully understand the spring loaded guide. belt is supposed to roll and convex no?
Ahhh ok, took it as he was using a 15, 16 or whatever in the kitchen...it's been a long dayOP said "Becker kitchen knives"
i just use a stone, they're very flat...
if they won't hold an edge, and the reprofiling didn't screw them up, i would suggest a professional have a look.
there is an EVER so slight chance a heat treat issue, but probably "wrong tool"
I'm a sushi chef, have always used the Becker set since I started but could never get a real good edge
