If the Graham is out of reach, look at his original knifemaking anvil w/o the horn. That will do just fine if you are focused on making blades and you won't miss the horn. Plus you can add a conical hardy tool if you find you need to down the road. All of the Atlas anvils have the mass centered over the striking surface, so you can get by with less weight because the mass is centered, making your strikes more efficient. It's well thought out.
Go to YouTube and search "How To Make A Mini Forge For Knife Making" by OUTDOORS55. I'd just link you to it, but that's against the rules here.....
There are many other good instructional videos out there, that's just the one I liked.
His is simple and inexpensive. I gave up on the MAP gas and got the Atlas burner, but it was like $60 or so for the excellent 30K burner, hose, and regulator. Well worth it for me vs. screwing around with MIG tips and hoping to get good performance with tuning. Lots of guys do it, and I'm sure I could too but my time is worth more than the cost of that burner. 2 bricks plus the burner, hose, & regulator (I added a steel frame and some IR refractory lining...also from Atlas) and you are into it for well under $100. I used the MAP gas bottle as the template for my hole, which is 3". That may be why MAP gas never worked out for me getting to forging temps. I have an inexpensive thermocouple hooked to a cheap multimeter that says I reach in excess of 2300F with that Atlas burner. Not sure how accurate that is, but whether it is or not it is definitely hot enough to forge carbon steel with. It's also very economical on the propane.
