Good Day.
I read the thread with interest on tempering, but admit that I will have to study the technical aspects to get a better understanding of it all.
I don't want to repeat the same issues, so will try and be specific:
I made a knife out of a file as per Walter Sorrells's video tutorial.
1) Normalized the file by heating in a fire and cooling overnight;
2) Shaped the blade, etc. with simple tools;
3) Heat treated by bringing the steel to non-magnetic and then plunging into warmed used motor oil.
Now, I may have gone a bit too hot, but the blade was hardened as a new file "skated" over the blade.
4) Put it in a simple oven at 400 F for two cycles of one hour.
The blade edge chipped badly on its first working day.
Questions:
a) Can I assume that all was fine until after step 3)? If it was hardened successfully (assuming), does all the fault lie at step 4? It is possible that the oven was irregular in temperature. (I have a better oven if needed!)
b) What to do next time?
Any advice will be appreciated.
Questions:
