How To Beginner Question about Sharpening and Angles
Hello.
Two months ago I purchased a Lansky Turn Box to sharpen my Delica. Worked with this device to try and learn proper technique, checked out YouTube vids. Was able to get the knife sharp, but always felt it could be a bit sharper.
So I picked up a used SharpMaker on the Bay to give that a go. Although I like the Lansky, the SharpMaker definitely is an upgrade. Enough background. Here are my questions:
-The angles stated on the Lansky are 20 and 25 degrees; the Sharpmaker is 30 and 40. I followed instructions on the Lansky, going from 20-25, moving from medium to fine. Should I do the same on the SharpMaker?
-Am I going to have issues using the Sharpmaker since I already went through the process on the Lansky at different angles?
-I assume I am better off sticking with either one system/angle rather than trying both. Will I cause damage or harm if I try to use both systems?
-Not sure I did myself a favor buying a used Sharpmaker, as the rods seem pretty smooth. Is this an issue? Do the Shapmaker rods wear out? Is there any way to tell, other than your knife just not getting sharp?
I also realize that I am new to this (only sharpening for about 8 weeks), so it very well could be me and my technique. Any advise would be appreciated.
Thanks for any and all help. This forum has been a great resource and I appreciate all the shared knowledge I have been able to pick up.
Looks like Lansky is 20 and 25 degrees per side. In sharpmaker terms it would be 40 and 50 angles inclusive. Ditch the Lansky and stick to SM. Pick up diamond or cbn rods.
Look up videos on microbevel so you understand what your doing better.
40 and 30 on SM are inclusive angles which transfers to 20 and 15 per side. Make sure your SM base is level if you want consistent results.
