beginner question
Do blades made from files and saw blades ned to be hardened? I made one from an Oberg file and it seems to be very hard already, does the heating of the blade when power sanding lower the hardness of the blade somwhat?
Kim:
Files are already hardened and you can ruin the temper if you get to much heat from grinding. Take your time and check the temperature often, I do this by touching it to the palm of my hand.
The only bad question is the one that is not asked.
P.J.
YES,it is sharp, just keep your fingers out of the way!
www.silverstar.com/turnermfg
Files are hardened steel, not tempered. You may have heated it enough to temper it some -- probably did if you weren't being careful not to.
Without tempering it's pretty brittle for a knife but it'll hold an edge like crazy and won't break if you don't abuse it.
I usually suggest tempering a file at about 400 degrees in a home oven before grinding, but since you've already ground it, why not use it as it is? Unless you want this knife for prying and rough use -- in that case you should temper it. Use an oven thermometer; oven thermostats are not very accurate. They always read low and the older it is the lower it'll read.
Saws are usually good for knives without any heat-treating. Of course grinding tempered steel takes longer than if you anneal it first but if you don't have the equipment to do heat-treating and don't mind it taking longer, go for it!
-Cougar Allen :{)
P.S. I meant 400 degrees Fahrenheit. Sorry, I don't know what that is in real degrees; I never can remember the conversion formula. One of these days maybe the US will join the twentieth century and we won't have these conversion problems....
-Cougar :{)
Cougar, couldn't resist
. I assume that you mean Celsius when you say "real degress". Subtract 32 from 400 and then divide by 1.8:
400 degrees Fahrenheit = (400-32)/1.8 = 204 degrees Celsius
>> DeWayne <<
thanks for the info, I appreciate it!!!
[This message has been edited by Kim McHenry (edited 13 March 1999).]
