Chad, we were all new once, no worries.
I recommend the 8670 from Carbon steel from @alphaknifesupply
It is the most affordable and best suited for rudimentary heat treat and a good performing steel when heat treated and processed properly.
It has very good durability and can be thought of as a stronger 5160 with slightly more edge holding and not really any loss in toughness to 5160.
You should avoid 1095, O1, 52100 right now.
They require more tempeture control to avoid making chippy.
Those steel have plus 0.80% Carbon and will not be ideal without proper temperature control since its too easy to put to much carbon in solution when austenitizing and make more brittle plate martensite vs more less brittle lath martensite which is desired.
8670 has 0.72 % Carbon so you'll not have to worry as much about making too much plate martensite if you put too much in solution, just grain growth or not fully austenitizing trying to avoid grain growth. 8670 also has other elements that help with the hardenability ( quench rate, not hardness) so you can achieve decent hardness with rudimentary quenchants like canola oil at 130 degrees F. Also the alloy additions will help keep more desirable constituents in the grain boundaries for a better matrix.
All steels will benefit from more temperature control which among many things will guarantee that you fully austenitize and prevent grain growth.
However, 8670 will be the most forgiving, affordable and available and is where you should start right now.
It will also offer you more as you grow as a maker.
Good luck.
As I'm just starting out I've been reading and watching a good bit trying to educate myself. I've made a few out of scrap steel, machetes and saw blades, just to cut my teeth without much cost.
I'm going to be doing stock removal for now and I've built a small oven (paint can and plaster of Paris) because I want to learn to heat treat as well.
Of course my question is, what steel should i start with?
(sorry if this has been discussed before)
