- Sep 13, 2006
Iam just getting started and was wondering what would be some good sharpening setups to start out with..... Can I use a leather belt for a strop or do I need a real strop? Thanks
Speaking as someone who owns diamond stones, waterstones, Arkansas stones, silicone carbide stones, and who recently tried his hand at sandpaper sharpening, I have to say go with the silicone carbide sandpaper method. IMHO it involves the least amount of money and has a very short learning curve. If you don't like the results (unlikely) or just want to try other methods, by mastering the sandpaper you'll be producing some very good edges for very little money in the meantime.
You could use a belt for your strop but sand it down till the nap is very short and tight, or buy some leather from the local craft store and do the same. The leather should be fairly stiff.
Here's an excellent thread on how to build a strop (Thanks to zyhano :thumbup:
Photos - demo: how to build you own strop
I also like the 'sandpaper' method. I use the wet/dry sandpaper on a leather strop block (instead of a mouse pad). I particularly like this method because it's essentially identical to stropping, just using coarser grits. In my case, since I'm using it on my existing strop block, the technique is exactly the same. Very easy to 'train' your hands to one technique, from start to finish.
My 'strop block' is simply a piece of red oak that I picked up at Home Depot, 2-1/2" wide x 1/2" thick, and about 5-1/2" long (length is entirely a preference issue). I used double-sided carpet tape to stick some leather to the oak (smooth side up). You can also use something like spray adhesive or contact cement. I sanded the leather with some medium grit sandpaper (like 220 or so), which gives the leather a nice, velvety 'nap'. When used with compound (green is what I use), the nap of the leather aids in holding the compound. When used bare (no compound), the nap of the leather really helps to make the strop 'pull' on the edge as you strop.
For use with sandpaper, I'd recommend using a separate block for that. This'll ensure that you're not getting your regular strops too dirty with the sandpaper sharpening process.
Sandpaper is best used in a progression of grits. Start with something low, like 220/320, maybe even 400, depending on how much metal you need to remove from your blade. Then, progress in steps beyond that. The progression would go something like 220, 320, 400, 600, etc. If you really want to polish your edge, you could go on to 800, 1200, 1500, 2000 and higher (the 1000/2000 grit will really begin to reveal a high shine).
That's about it. I use a length of 2x4 (seven inches I think- can hold standard 9 inch paper) with a piece of leather cut to fit, laid over the top. The short ends have a slot cut in them to accept the ends of the paper and I hold the ends in place with small wedges. All my strops are mounted to their own 1x2.5" boards. When its time to strop, I just put them right on top of the sanding block and the friction holds them in place. I've only been doing it like this for a few weeks if even - did it just to satisfy my curiosity. Have been hand sharpening with bench stones of all flavors for many years and am plain impressed with how easy and fast it is to get extremely good results. Started out w/ a mousepad, but felt that was a bit too convexed for me. Using some fairly hard leather yields an edge only slightly more convexed than what I get from a stone. For comparison, 320 grit will be toothy, but still clear-cut arm hair, 1500 grit paper produces a finer edge edge than an EF DMT (IMO) and 2000 grit stropped on green compound will be sharp enough to shave your face (produced a finer scratch pattern than 5 micron lapping film). I may never go back to bench stones.
The "sandpaper" method is something I might try... This is a silly question, but do you pull the blade as opposed to cutting into it like a stone? Ive got a benchmade in 154cm that is hard for me to get a good edge on.
If it's glued to glass I believe you can push or draw. I draw, using the exact same motion used for stropping. There are plenty of videos out there that cover stropping and some that deal specifically with sandpaper. Whatever you go with, bring plenty of patience, a cheap/disposable knife or two, and a Sharpie for telling where you're grinding on the edge.
HH
