Wouldn't it last a lot longer if the leaf blower was AFTER the filters???
How loud is it?
For full 70’s sound dampening , it has to be Sunshine Orange or Avocado Green shag carpet! ;-)You could build an upper box over the blower and line it with shag carpet to attenuate the sound.
Great apparatus !! Just a thought for you. Dry Sawdust is what burns, combusts, unless you Grind Aluminum & then Steel and make a crude Thermite which can burn your place to the ground.Actually, the opposite. It’s only for metal.
There’s water in the bottom of the bucket to kill off the sparks but, even if a spark makes it through, the worst I’m looking at is burning a hole in my filter.
I wouldn’t use this for wood because I don’t want to run it through the water (who needs soggy sawdust) but, without the water bucket there’s nothing really protecting the impeller fan. If a bigger chip made it down the pipe it might turn into a bullet.
Could you re-post it larger?
