- Nov 1, 2006
I am pretty decent holding my blade at the angle I desire but surely not perfect. Thought how could I make my Kalamazoo set for the angle I want. Below are some of the shots I took so that you can also see how simple it was. You can take any belt grinder and mount it on a plate. I use 3/8" aluminum that I had laying around. You can even use plywood.
1. Mounted the grinder base to the plate and added a piece of hinge to the back. This will be the pivot point.
2. Mounted a piece of angle iron to the front of the plate.
3. Drilled two clearance holes on each end for 3/8" threaded rod. Added rubber ends to the rods. (optional)
4. Used four 3/8-16 hex nuts for making angle adjustments.
5. Added a small level to angle plate. Helps to adjust each rod evenly.
I now can set my angle cube on the machine and adjust from 25 degrees per side down to 0 degrees.
Holding the blade 90 degrees to the bench you can sharpen to the angle you want with quite a bit of accuracy. IMO
Remove threaded rods and the grinder is back to 90 degrees on the bench. Will look into making a gauge to make the adjustments a bit faster.
Thanks for looking
Ron
Thanks for looking
Ron
