- Apr 29, 2012
Guys,
I want to build a 72x2" belt grinder and i need your experience .
I am thinking a 2hp motor 3phase at 1400 rpms with a vfd inverter.
The motor will have a 4" drive wheel directly attached .
First concern is the rpms. The 1400 and the 4" drive wheel give me about 1450 sfpm and the 6" drive wheel about 2196sfpm.
Witch one do you think is the appropriate?. I heard that the vfd is able to increase the rpms but i do not know how much OR if it is better to use a 2800 rpm motor so the values of the sfpms will double and instead of having the vfd to increase the rpms i will decrease.
For example
A) if iuse 2800rpms with a 4" drive i will get 2850 sfpms that is ok but how much is the lower limit of sfpm?if i need to run at 1000sfpm i will need to slow the motor to 30% ??? Is that ok with the motor?
B)if i use the 1400rpm with the 6" drive wheel and the 2196 sfpms i will be able to get slower speed much easier but i will suffer at the high.how much a vfd can increase the speed?
Please note that i do not know how much will be the rpms drop when the machine is under load.
Second concern i have is about the inverter types.there are cheap ones and expensive. the difference is the sensor less vector technology that i do not know what it is and if i need it.can someone please let me know if i need such a type for a belt grinder and what it does?
For example
