I FINALLY got my Kalamazoo 2x48 belt grinder, for a little over 200 shipped.
I had the GREAT fortune of getting a 1HP Baldor motor for just the cost of shipping (it's heavy, but still a great deal), so today I had to put it all together. First I reversed the rotation and set it up for 115V so it all went the right way (not sutoo bad, though I had to do some major re-wiring).
The grinder has a pulley and a belt with it, so all that was left to be done was removing the stupid yellow shield from the unit.
The motor has a 5/8" keyed shaft, and it took me almost 3 hours driving around town today to find a drive pulley for it, but I finally happened upon Grainger and it turns out my college even gets a discount, so 10$ later I had the pulley and key in hand.
A trip to Home Depot set me up with a precut piece of MDF and the needed nuts and bolts for about 20$, then a couple bucks later I had two small right-angle framing strongties and I was almost good to go.
A drill bit purchase and I was ready to start.
The motor is a 56C mount, so there's no easy way to keep it from jerking around (capacitor start) when you turn it on. After cutting (my Dremel tool is worth its weight in GOLD!) the strongties up to fit the motor, I drilled a couple of holes, screwed the brackets in with drywall screws (cut off the excess sticking through the bottom with Dremel) and screwed the 3/8" hex bolts to the face. Voila! It doesn't move at ALL now.
Next I drilled two holes for each of the mounting bolts on the grinder, and jigsawed out slots inbetween them so I could adjust it for belt tension.
And here I am, with a belt grinder, fully functional and ready to take all the belts I got for it.
You'll notice a hint of how I'm doing with my first (ever!) knife on the MDF.
Not too bad for a kid with basic tools in an apt. working on his porch couch for a day, eh?
All totalled I spent around 300$, and got a 1HP grinder and 60 grit 3M 977 ceramic belts will fit it, so rock on!
I can't wait to get started this weekend.
Thanks for lookin
_z
Thanks for lookin
_z
