Which one? What happened to it, if you don't mind?The Chinese grinder just took a dump.
I run mine in reverse without issue. Of all the grinders I have and have used, the TW90 has the best tracking by far. To the OP, TW90 or Burr King would be my choice.My issues with my TW-90 are:
No reverse switch -can't run in reverse for sharpening and some other reverse tasks.
1.25" tool arms - can't be used with other tool arm accessories or other grinders.
Tracking adjust is a little wonky.
While I like the ratchet tensioner, it is hard to determine when it is set right. No index for repeated use.
Tool arm lock lever is on the wrong side and gets in the way of the belts when changing them.
Unfortunately Northridge Grinder is no more.Northridge Tool is another top of the line grinder to consider in getting a good overview of available machines. A couple others that haven't been mentioned are Beaumont Metal Works KMG, Bader B-3. There are also a couple European grinder manufacturers who seem to be of high quality.
Stacy E. Apelt - Bladesmith There are enough of these inquiries that I wonder whether it's worthwhile to consider including a comprehensive list of available 2x72s and other grinders in a sticky?
