belt grit
deltablade
I am starting to use a belt sander to regrind the edge on some machetes. could anyone tell me the right grit or grit sequence to use?
I'd set the edge with a new and sharp 220. Maybe even a 150 if it's really abused. Then move up from 220 to 400 and finish it on a dull 400 or 600. Careful not to overheat when grinding. Take a pass and let it cool or dunk it in water.
A working machete doesn't need much more than that. I'd say a 220 and a 400 would get you by just fine.
--nathan
many thanks, Nathen
--nathan
Sam has a good point. I typically go way higher on grits for edges, but for a machete, you don't really need much. 120-220 will leave a very toothy aggressive edge. It won't push cut paper, but it's a freaking machete :D.
--nathan
A filed edge works really well on light flexible plants, like grass and those *&()^ rose bushes with the tiny fragile thorns. I usually use 120 or 180 for sharpening, followed by a power strop on a leather belt made for the belt sander.
