- Oct 21, 2019
Just curious as to what you all do in terms of finishing belt progression. I have been doing my bevels with 60 to rough, then to 120 to get my bevel to where I want. With the lower grit belts my grind lines and plunges look great.
Once I move to finishing belts is where I usually end up chasing little mistakes and my bevel ends up higher on the blade than intended. After 120 I have typically been using a 220 Hermes ceramic J-Flex. I find that it cuts great for the first couple of passes and then tends to start to wash out. I have a couple Trizact belts that I may try as finishing, but I have found they haven't worked well for the rounded plunges.
What do you guys go with to finish your bevels?
