Recommendation? Belt sander build
Thanks for letting me join. I currently have a 4 inch Harbor Freight belt sander with the side disc sander. It works but its not ideal.
I've been looking up 2x72 setups and I want to make one. I'm trying to put together my list of parts.
I have an old table saw in storage I was thinking of stealing the motor out of. Do you guys have a recommendation on the wheel size I should put on it? I think I want to have variable speed too.
Is there anything I should do or not do that you all have learned from your setups?
Thank you,
Matt
I built the one listed as well, works perfect after shimming certain areas like directions state.
+1 Mine took a bit of shimming/adjusting to get it running straight because there is play in the insert that the tracking wheel is mounted on. Once I got that shimmed up and not able to move it has worked great.
I plan to build the one that Hubert S. gave you a link for next.
I would strongly suggest going variable speed. It great to be able adjust speed in seconds. I watched Craigs for a while and got a 3phase motor for under $100. I bought a second hand vfd for about the same amount. There are lots of Chinese VFD's on Ebay for about $100that guys are using and they work well. You just have to build an enclosure for them because they are sealed.
