- Nov 11, 1999
I have always been a sharpening fanatic, but have been getting tired of always having to do it by hand. Also had issues getting the tip as perfect as I liked using benchstones or the spyderco 204. So I bought a Delta SA180 belt sander, cheap Ryobi bench grinder and a paper wheel set to put on the grinder. Only had it a day now, but wow am I ever enjoying it. Very proud that my first 10 knives sharpened came out with very nice and even bevels combined with very pointed tips. Now I need help in obtaining the best belts for the job and could use some advice.
So far, I have only two belts. The 80(ish) grit belt that came with it and a Norton Blue 220 grit belt. Both seem to take metal off at an astonishing rate and both end up extremely sharp after finishing with a couple of passes on the paper wheel loaded with white rouge. On that note, I am getting edges that our actually scary sharp beyond anything I have done by hand. I could always create a shaving edge, but these are something else. I do suspect that the edges put on with the 220 grit will last a little longer.
My question is, what do you think would be the best type and grit belt to use for sharpening like this? I like the idea of keeping one belt on the sander and then continuing to finish on the paper wheel. Is there really a best grit or does it just depend on how toothy you want the edge?
Really appreciate any tips! Thanks.
