- Oct 13, 2013
Hello, everyone. I've been belt sander sharpening for the better part of 2 years now and there are somethings I have had problems with and woulkd like to speculate with you guys on possible solutions
Problem #1
Reprofiling Machetes/Axes compared to knives.
When sharpening knives, it is wise to use as light of pressure as possible for sharpening/reprofiling, but with machetes and axes, heavier pressure is required (for me) or I'll be standing at the sharpener literally all day long just to reprofile, even with an 80 or 40 grit belt. Is applying more pressure a valid solution to this problem? It certainly takes a lot less time to remove that heap of steel needed to get the kind of edge I prefer. However, using this heavy pressure on knives would likely result in way to much steel being ground off. Agreed?
Problem #2
The tip.
I cannot stress enough how important it is to NOT drag the blade all the way across the belt. The belt will wrap itself around the tip just long enough to rip it off. This is why i take the tip halfway (at most) across the belt and simply back off. I think this has been discussed before multiple times and agreed upon.
Problem #3
Rounding off the apex with the leather stropping belt.
I have done this so many times before I actually realized what the problem was. I didn't think that the leather belt would have more flex than the abraisive belts. The belt does almost the same thing the abraisive belts do to the tip. It wraps around the apex and knocks it off, doing MUCH more harm than good. How to combat this? Feather light pressure.
Problem #4
3M Trizact 6 micron belt leaving black on the edges.
I know this sounds strange, but after I use the 6 micron trizact belt, my edges will sometimes have a blackened coloration mixed in with the mirror polish. It's not burning the edge, because there would be other colors besides black and I keep the blade cooled off anyways, and it isn't a dirty belt because I uyse a cleaning stick. This is the one problem that absolutely baffles me. Does anyone have any idea why in the world this happens? It's a huge pain to see an ugly black stain on the perfect mirror you worked so hard to achieve
Thanks for reading, and please feel welcome to discuss these problems and other possible solutions to them, please
Problem #1
Problem #2
The tip.
Problem #3
Problem #4
