the wheels are all custom made bader wheels, and i watched them running. the crown should be true, since bader has been doing this for a while. the only wheel that's crowned is the idler wheel.
today i tried to get rid of some of the movement in the back arm by putting some lateral tension on it, that worked in taking some of the vibration out of it. could vibration in the arms and platen be causing the belt wonder?
i have a burr king tension unit, so i can put a pretty lot of tension on the belts if i need too. i don't have any experience is tensioning big belts though. i'll try messing with the tension.
A.T. i'll keep your suggestion in mind, thanks. have you tried it? how good does it work?
thanks for helping, i appreciate it.
