Harbor freight has one that is 30$ with a coupon, many people have had them for awhile with no problem. The extended warranty is cheap insurance in my opinion. They run fast so you need to have a light touch and be careful. As far as"quality" goes you could get a Kalamazoo for under 300$ but that is 1X42. Hope this helps... Russ
Yep I'm using the 30.00 HF 1x30 as well.
If you put too much pressure on it, you're gonna regret it. But just let the belt do the work, and buy the appropriate belt for the job and I don't see how this could not handle any 1x30 belt sanding task. You really must use the appropriate belt for the job. It takes less then 30 seconds to swap them out.
Currently using this for my custom Enzo trapper on the piece of burl block I bought for the handle and it is finishing up super nice. Less then 30 minutes on the belt from a huge square block and I am already transitioned to hand sanding at 120 grit.
I have also used it to completely regrind a flat grind S&W flat grind blade (1095 steel) and worked like a charm, after removing their black coating.
edit: here's the handle i'm working on, which is far from finished - these pics weren't meant to be a tut or anything, but my brother keeps bugging me for pics because I think he wants my knife. So these are a couple i've taken along the way, all done on the HF 1x30:
http://imgur.com/a/a21ir
I tried my out an decided to use keep it. I have a 120grt,400grt, 800grt, 1000grt, and leather stropping belt on the way was we speak. I going to practice on some of my cheap knives before I use it on my nice ones.
So you don't catch the edge of the knife on the belt running at 3000 feet per minute.
