belt sander
is this a good sander ? or are there better ones ? dont wanna spend too much ...$ 100 or less ...thanks,,,,
1'' x 30'' BELT SANDER
Powerful 1/3 HP motor runs at 3400 RPM for fast stock removal and a smooth, flawless finish. Removable back plate permits sanding on curves or odd-shaped stock.
Table tilts 0 to 45°
1-3/4'' dust collection chute
Durable die cast & machined aluminum construction
Motor: 1/3 HP, 120V, 3 amps, 60 Hz; Table dimensions: 5-1/16''W x 5-1/8''L; Overall dimensions: 9''W x 11-1/8''L x 13-1/2''H; Weight: 13.30 lbs.
ITEM 2485-4VGA
$39.99
$32.99
found it at harbour freight,,
This is the Harbor Freight 1"x30". I have been using it with a leather belt from Lee Valley to strop. For $29 plus the cost of the leather belt and a few grinding belts it has done OK. I hope to move up to a larger one some day...
would it be good too sharpen with,,i mean maybe 80 grit,,,200...maybe up to 800 grit ?
You can often buy reconditioned ones at some rental places for very cheap, meaning you can buy much larger ones for the cost of a small 1" sander. This is useful if you want to move beyond just reshaping a small bevel and actually working on the primary grind of a knife.
-Cliff
Belts aren't hard to find... and you can also use 1x42 belts. I actually have that Sears grinder. It does OK... but it seems like something is always in the way on it... part of the guard... I had to take the tension handle off... etc. Makes it a bit limiting. It won't run a leather belt at all... the guard in the back would need to be cut away... and I didn't look close enough to see if I could do it. I think I read somewhere that someone had done that... but cant remember where. I mostly use it now for big jobs... and am looking to replace it eventually. Mine's loud too... I have to wear earplugs with it.
The one I like for sharpening is what Lee Valley sells....
http://www.leevalley.com/wood/page.aspx?c=2&p=44884&cat=1,43072
you have to get a motor for it.
Others may chime in... but the Sears grinder is not my favorite.... expect for larger jobs. While at first I liked it... the more I use it... I'm not as impressed. I wouldn't say it's bad.... if you get one, I'm sure you could get it to work... just not my first choice.
i think im gonna stick with the harborfreight model,,,noise would be a BIG issue for me,,,
