I've been looking around at some belt sanders. There seems to be a lot of talk about 1x30 machines on here, specifically the Harbor Freight version. I've used much larger sanders in the past. I think the ones we had in school were 6" wide stand-alone units (never sanded steel, just wood on them). The last one I got to see in action with blades was a home-made unit in the 4-6" range. A wider belt seems like the way to go for grinding blades, whereas I don't see the smaller 1" belts dong anything more than sharpening.
Woodcraft has a 4x36 bench top combo belt/disk for $140, Rikon http://www.woodcraft.com/product/2083575/35727/rikon-4-x-36-belt-and-disc-sander-model-50112.aspx. Would this be a decent unit to start with? What about the speed? I don't see any that are variable speed but something tells me that would be ideal. Does anyone have experience with the larger fixed speed belt sanders that they can share? If I made a sander it would probably cost me a lot more than the Rikon to make by the time I was done with the steel for the frame, rollers, motor, pulleys/belt if I did belt drive, etc.
