Hello there,
We have a kitchen knife repair shop.
We have been using Cubitron II of #36, #60, #80 and #120 grit.
The Cubitron models used 784 and 984.
Application:
Flat grind of kitchen knive geometry.
At the spine 2mm, width of the blades aprox 50mm.
Flat grind to aprox. a 0.3mm thickness 0.6mm from the edge.
Steel:
high carbon which has high aloy and it is stainless steel (440c, VG10, 10Cr, S35V, S110v, Elmax, M390, K390)
784/984 issues
The belts work ok with up to 2 knives.
3rd knife starts take longer to work on.
4th knife is even slower and I have to use more pressure....using more pressure results in burind the very thin tip of the edge.
Does any one has please PRACTICAL experience and could recomend a suitable belt of #80-120 grit which can be used wet and wth low pressure?
Also could you please post a magnified pictures of the belt surface?
Under the microscope I could observe totally different structure as advertised on 3M website.
I look forward to hearing back from you.
Application:
Steel:
784/984 issues
