BA_Colt
Don't make me slap you the kielbasa.
- Oct 15, 2008
I recently bought a Benchmade 111H20. I sail and kayak on salt water and wanted a folder. orginal thread on knife parameters It is the partially serrated version with black scales. I carry a marlinespike that has a shackle key so I did not need a knife with a spike. I spent the other day sailing, winterizing, and whipping all lines on my friend's sailboat so the knife got a good workout. First off the knife has a good weight to it, and well balanced. The scales have an aggressive texture which could become uncomfortable if you spent time carving a spoon with it, but for line cutting and rigging it is great as they do not get slippery. I dunked it in the water a few times to see how good the grip is and never felt in peril of losing it overboard. The blade has good thickness and the serrated part cut through line and rubber reinforced tubing like warm butter. The factory edge on the plain part was even but not hair popping sharp. I touched it up freehand on a DMT diamond fine and it took a edge well. It has an ambidextrous thumb stud and opens smoothly with the stud or with a flick. I tested opening it with leather gloves on, neoprene gloves, dry then wet. I could always get it open and locked. Here is the only real con. The Axis lock. Opening it with the Axis lock and a flick worked maybe 60% of the time, and with gloves on around 30%. Also closing it with gloves on was troublesome. The lock however held the blade well and I am not afraid it will slip. I have added a lanyard and the lanyard hole is a good size. The pocket clip was a bit tight but with a little persuasion it works well now.
Thanks bdt0307 and Pete1977 for the heads up on this knife.
Beth
Beth
