Benchmade 15050 Bone Collector Lockback
I first saw this knife on a You Tube clip from the 2012 Shot Show featuring Benchmade's new knives. The knife caught my eye as it is not that common for a major player to introduce what is a relatively old fashioned style of knife. As usual there can be some delay between announcements and retail availability but I eventually got my hands on one.
What is relatively unusual about this model is the absence of thumbstud, flipper, hole in blade etc that facilitates one handed opening. The lock is the tried and tested backlock. There is more than nostalgia at play here. I live in Australia and we have recently experienced a crack down on importation of evil items like one handed openers. I can own one legally where I live but can't import one. I ordered this Benchmade from an on line dealer in the US and it passed through Customs without a second look. I might say more but this thread is about a knife, not silly laws.
The 15050 is part of the Bone Collector series - I am not really sure what that means and haven't paid much attention to it. The first thing that struck me when I opened the box was that the knife was a lot bigger than I had anticipated. My fault entirely as the seller quite clearly published the specs, but from pics I had imagined a more compact piece suited to the pocket. While on the subject, the dimensions are (from the manufacturer's website) :
Blade length: 3.73
Blade Thickness: 0.130
Handle Thickness: 0.53
Overall Length: 8.48
Closed Length: 4.75
Weight: 3.750z
Blade Hardness: 60-62HRC
The knife is made in the US
The Blade is D2 steel in drop point style and is hollow ground. The scales are cocobolo with some Bone Collector inspired decoration. I believe that a micarta option is offered but I have not seen one for sale. The bolsters and liners are alloy or brushed stainless; I am not sure which but a magnet will not stick and with the light weight of the knife, I would guess alloy. The knife does not come with a sheath but does have a pocket clip which allows for right hand, tip carry or nothing. The clip is removable. The blade has an adjustable pivot that I did not adjust as it was set just right for me. There is no provision for a lanyard.
The blade has an adjustable pivot. That is not a gap between the bolster and the scale - the edge of the bolster is angled out towards the bottom.
There is postive jimping on the blade and spring
My impressions.
As previously mentioned this is a large folder - roughly the same size as a Buck 110. For its size it feels surprisingly light in weight. Appearance is a subjective thing but I find the knife attractive. The knife locks up tight with no discernible play. It opens and closes smoothly. Somewhat surprisingly for a locker it has a half stop. The 15050 is held together with torx screws and appears to be amenable to disassembly, though I did not attempt to take it apart. Fit and finish, with one exception, is first class. Inside the frame looks almost surgically smooth and clean - no casting or grind marks anywhere in sight. The grind lines are faultless and the blade was hair popping sharp out of the box. It feels secure in the hand.
Not sure how clear it is but note the gap between the scale and frame under the pocket clip
Overall length is similar to the Buck 110. The 15050 is longer than the Griptilian but thinner in the grip
The exception issue re fit and finish might be better termed a design issue. In one section the wood scales are clear of the liner/frame. I could move the scales with finger pressure and see the gap opening and closing. A pic is included - not sure how clear it is in the photo. Tightening the screws has no effect. For a knife intended for hunting and the outdoors where blood, mud etc are likely to be encountered, the potential to get gunk under the scales is obvious and corrosion might result. This was an unfortunate discovery in what is otherwise a knife that is well designed and is built and finished to a very high standard.
That's a pretty clean folder. Saw one at a local store store the other day, but didn't had enough to buy it so I settled for a Tenacious. The wooden handle bc is definitely on my list of future purchases
Good review. Thanks for taking the time to post.
I'm getting one too, but haven't decided on the scales. I'm leaning towards the cocobolo. I was surprised to see, that its bigger than the Griptilian. Can you post a picture in the hand?
And how has it performed so far?
The BM folks at the Blade Show had the green Micarta lockback folder BC to see - said it would be shipping soon. The cocobolo one is 15050-2, which makes the green Micarta one 15050. At $120 MSRP, it is $10 more than the base 551 Grip and $10 less than the cocobolo version 15050-2. My 15050-2 cocobolo lockback folder in cocobolo has bumped my two-tone G10 large BC and walnut small BC AXIS locks out of rotation. My wife still prefers her walnut small AXIS lock BC to my new one. Neat knife - great value. Good review - doubt I'd clean even a fish with mine, however.
Stainz
It has a half stop? Weird.
I was looking at one of these with the idea of putting a "one-armed bandit" on the blade so i could open it one-handed.
I guess the half stop would prevent that from working properly.
Too bad as i own no Benchmades and wanted to try the brand.
A half stop shouldn't be a problem opening wih the bandit. It should be more a safety feature dhring closing IMO. That is by pushing throughout the opening. It might be a problem if you plan to thumb flick it.
I recently ordered a large axis bone collector in walnut and was accidentally shipped this knife on accident. I was looking forward to getting my first BM product but sadly I'm still waiting for the correct one.
When I opened the box to find this knife I was not happy, but it is a very clean and classy looking knife. One thing I noticed right out of the box was that when the blade was closed it was loose and bounce back and forth freely between the liners. It was tight when opened up with no play, but the looseness when closed wasn't something I could be happy with.
The walnut was looking good but felt very very light and thin.
I'm hoping the large axis BC version is better when I get it.
They just look so good. Hopefully mine will be here this week.
Post deleted (I should have read the thread more carefully as my query was answered!)
Allan
Thanks for the review. I see what you mean, just looking at it the size is deceptive and it "looks" like it would be smaller that it's dimensions. I have more "tactical" type folders already, I like the idea of something a little more "old school" sometimes.
Mist i just picked up a Cold Steel Mackinac Hunter, so far i'm loving it! Similar in size and weight to my Buck 110s but with the very strong Triad lock and a few things which the 110 lacks, mainly a lanyard hole, two position pocket clip and dual thumbstuds. While the faux stag panels are smooth and not as grippy as i would like they are as grippy as my Buck 110s. And the Mackinac grips are screw attached so one can add custom scales quite easily.
We sell this blade where I work! The first thing I noticed upon holding it was how light it feels in the hand. If anyone gets a chance to hold one I'm sure you will think the same. Nice knife overall great fit and finish!
I just discovered this knife and also live in Australia.
I googled for a review and this thread was the top result.
A light weight lockback with a quality steel, trying hard to not pull the trigger on one.
Thanks for the review, great photos
I like mine. It's a worthy modern take on the old Buck 110 ( 440C than 425M than 420HC) , Gerber Sportsman ( 440C standard, Vascowear upgrade "V" steel in the sportsman 2), and Schrade LB7 ( 440A). Price isn't bad taking things into account, steel is good, finish good etc. It's a good knife and should last a long time in the pocket. As a model? Good question. I'm glad I got one though.
