- Mar 2, 2014
Somehow I like Benchmade 154cm better than Spyderco vg10.The edge just seems to have more bite in it.It also performs just little better for my uses.Maybe I am wrong, but would like to hear other peoples opinions.
Interesting. I own both of those knives as well and I feel the exact opposite. I much prefer the VG-10 over the 154cm. Easier to sharpen and in my experience holds it longer.I have a minigrip in 154cm and a delica 4 in vg10 and i like benchmade's 154cm alot more. I sharpen both knives exactly the same and i feel that the 154 holds not only a razor edge but a working edge longer too. I will say that the benchmade also holds a sharper working edge Too. I felt like the vg10 stayed razor for a while but basically skipped over a working edge and went to dull. I like 154cm in general better than vg10 overall.
Can't speak about spyderco's vg10, but I've had BM's 154cm in three knives and each time I found it to be chippy. I had to keep the edges at about 40 degrees inclusive just so the steel wouldn't chip out on me. Third time was a charm and I decided to give up on 154cm, at least from BM. I also found the same issue with their D2, finally giving up on BM altogether. Other knives from other well known manufacturers haven't had close to the same issues. I keep my s30v blade also 30 degrees inclusive, my PSF27 blade at 18 degrees inclusive with a 26 degree inclusive tertiary bevel, and my Elmax blade at about 24 degrees inclusive. No problems on any of them. The only problem I had any of them, and it wasn't really a problem, was that I took that PSF27 to 9 degrees per side and the edge was very unstable in my normal duties, leading to the tertiary bevel. It cuts like a demon.
