Benchmade 51 Loose Latch Question
So just a few minutes ago I tried switching the pocket clip on my BM51 from one side to the other. Afterwards, for whatever reason, the latch wasn't as "springy", So I simply put it back to the original side no problem. Now though, the spring latch seems to be totally loose and even has some play up and down between the two handles. I could be mistaken, but I don't remember it ever doing this before. Another weird thing is, no matter how much I tighten the screw at the bottom, it does not change the resistance on the latch WHATSOEVER. If I recall, there wasn't original much play and you could adjust how loose or tight the latch was by simply loosening or tightening the screw at the bottom. Can any other 51 owners let me know if that's how it's supposed to work, and if so, why mine isn't working properly? Thanks for any help!
Try posting on the Benchmade forum,, and for sure contact Benchmade, their CS is top notch.
Thanks! I tried over there as well. Oh yeah, I love BM's customer service, but I would like to avoid sending it in for something I'm sure so simple. Are they typically able to help for things like this over the phone? Or will they tell me they'll have to look at it in person?
Give it a try,, I called them regarding a little blade play, and to make sure if I used Loctite on the pin I wouldn't void any warranty or anything,, they were super helpful.
