- May 5, 2000
I've had this one for a couple of weeks now. So, with a little more experience:
The Good
The knife came with a very good edge. Far, far better than the late-1990s Benchmade edge. The ergonomics are terrific. I've already noted on the Spyderco forum that they really need to make a slick-opening, heavy knife. (All their tank-like knives are lockbacks, and all their slick knives are lightweight.)
The Bad
Even after copious working of the lock, the 520 didn't have that absolutely effortless, fluid opening of the 710. It was by no means bad, and if I'd never had my 710, I would've been very impressed with the 520. But I can open the 710 just by thinking about it. It's absolutely effortless. Combine that fact with the way it locks open tight and stays closed right, and you have the best lock ever. If the 710 is a 10 on a scale of 1 to 10, the 520 is a 9.
Then I figured out why.
The black coating on the liners is in (at least) two places where it should not be. The most obvious is the Axis lock bar itself. That's right--the bar that rides against the round end of the blade is coated in the black stuff. The coating is also on the parts of the liner where the bar rides (the cutouts as well as the sides where the thumb-pull things sit).
If you've had this knife for a little while, go ahead and rotate the lock bar by hand. (Grab it between thumb and forefinger and just spin it.) You'll see the spot on the lockbar where the black coating is starting to wear off.
Not being the patient type, I made a tiny sanding stick and polished off the rest of the black coating. (I did this after an hour of manipulating the lock halfway by hand and deciding that it would take another two weeks to get where I wanted.) I blew it out with some Ballistol (the only thing I have under pressure), and it already feels better. I'll clean it out again and then use some FP-10; it should be much smoother than before.
(As an aside, I'm hesitant to flush out the whole thing with hot water and soap because the Axis setup seems like it has places that might not dry too well. Does anyone have actual experience cleaning their Axis like this? Should I just go ahead and do it?)
More impressions to come, I'm sure...
The Good
The Bad
