Benchmade 556 Pardue Mini-Griptilian vs Spyderco C78 Native III
556 Mini-Griptilian
Pros:
Dual full-length steel liners for strength.
Flat-ground blade.
Very effective handle texture for non-slip grip.
Very secure pocket-carry.
Torx screw construction allows for an adjustable pivot and disassembly.
Axis-lock strength and ease of use.
Very compact design.
Cons:
The integrated guard shortens the grip.
Its screws can become loose and possibly lost.
Possibility of broken omega-springs, compromising the lock.
Difficult to clean between the scales and liners without disassembly, places for gunk and debris to build up.
The screws used to secure the pocket-clip and connect the scales to the liners are excessively long and intrude in to the blade space.
Native III
Pros:
Rivet-pin construction eliminates the possibility of lost screws.
The reliable lock-back design offers very little that can fail.
Very easy to clean and maintain with no hidden areas for debris to build up.
The wire-clip is very easy on cloth for pocket-carry.
The FRN handle is thicker and stronger than the typical Spyderco FRN folder handle.
Cons:
Hollow-ground blade.
Wire-clip does'nt seem as secure as the traditional clip.
Handle design does'nt offer as many different grips--not as versatile.
Because of the rivet-pin construction, you cannot adjust the pivot or disassemble the knife.
The bottom line:
Both of these folders are very nice high quality knives from two of the best knife companies in the world. You simply cannot go wrong with either one and I don't regret buying either of them.
But if I had to choose one over the other, the Native III would be the one.
The 556 has one of the best blades I've ever used on a small folder. The flat-grind and edge geometry makes the 556 the better slicer of the two knives.
The problem is that you really cannot take full advantage of that great blade because the handle grip is too short.
The choil formed by the handle and blade of the Native III allows for a strong secure full-sized grip.
While the 556 is no doubt the stronger knife due to the dual steel liners, the thick FRN handle of the Native III is plenty strong enough for a folder this size.
Also, the Native III is about as "worry free" as you can get in a folder. There are no omega-springs to think about and no screws to worry over. Torx-screws are great until you have a loose one and you're many miles from the nearest screw-driver.
So, if you're searching for a smaller folder with a full-size grip that's also sharp, reliable, worry free, with premium blade-steel, give the Spyderco Native III a try.
Good luck,
Allen.
556 Mini-Griptilian
Pros:
Flat-ground blade.
Cons:
Native III
Pros:
Cons:
The bottom line:
Good luck,
Allen.
