I can't really speak for the Skirmish except to say: I've fondled it at least twice and the knife is huge! It's thin, but it's one big, stout, folder.
The mini-Skirmish is exactly the same, just smaller and thinner. The frame lock on my mini is very secure. I carry it in the waistband, so slim is nice. The knife came razor sharp out of the box. I have BM's in S30V, so I know I'll be able to sharpen it without much fuss and it'll hold the edge more than adequately. The fit and finish were typical BM....very good.
That was the good. Now for the bad.
The frame lock was exerting too much pressure on the blade at the pivot, in my opinion, causing the knife to rest off-center within the frame. In fact, on closing, the edge hit the rearmost spacer and chipped the blade. If you look at the frame spacers, you'll see they're shaped like inverted barrels. If the blade is centered, there is ample clearance, however, there is not enough clearance if off centered. In my case, the blade was off-center enough that the side of the blade was gently chaffing the inside of the frame on the side opposite the frame lock bar. The chaffing was occurring down closer to the tip of the blade.
That knife is, as we type, on its way to Benchmade for some rest and relaxation. When it returns, I expect it will be like new...... with blade centered between the frame and blade-edge restored....and sharp!.
