Benchmade 630 Skirmish
I received this knife through the pass around forum to use for a week and review. The dimensions from the Benchmade web-site match the sample of the knife that I have, except for the length of the handle, which on this one is 5 3/8” long. The other item that I often look for is the thickness of the knife, this one measures 0.460” (without the clip) and for those who are interested the washers are phosphor bronze, the obverse side being slightly larger than the reverse side. I can’t give measurements of the washers as this is not my knife and I won’t be taking it apart.
If you are in the market for a LARGE folder, this is one worth looking at. The blade opens and closes very easily and smoothly. The lock is easy enough to manipulate without being released inadvertently. For a knife of this size, it carries well enough in the pocket, I carried at work (did not use it in front of anyone) for most of the week, wearing Dockers, and while I knew it was there, I could live with it. This is due to the thinness of the handle, which has the pro of being comfortable to carry and the con of getting uncomfortable for extended heavy cutting chores. I used the Skirmish to point some fallen Oak branches; it worked, but after a short time, you realize a thicker, rounded handle would be easier on the hand. Everything is a compromise, somehow.
The model that I reviewed is anodized green with blue to gold accents. A very attractive package and the anodizing is holding up well.
The knife arrived with last 2” of blade very sharp, but the rest needed to be touched up and the blade had a couple of small chips out of it near the tip, one of which is explained below. The blade sharpened up very easily to shaving sharp in less the ten minutes time.
Three items I particularly like about this model. First is the clip. It has enough spring to it to stay put, but it is not so stiff that it only works well on certain slacks. Most knives with clips that I have used are too stiff. If you put enough bend in the clip to hold well in say dress slacks, they are to tight to be used in a heavier pair of jeans. If you loosen the clip enough to hold well on jeans, they don’t hold on to thinner pants. This clip also doesn’t get in the way of your hand when holding the knife.
I also like the opening hole better than the more common thumb stud. I find is easier to use, it doesn’t get in the way of sharpening the way many studs do and it doesn’t catch on your pocket when removing the knife. It is nicely chamfered, which adds to comfort when repeatedly opening and closing the blade, but this also makes it slightly more difficult to open with gloved hands. Like I said, there are always compromises.
The third positive feature about this knife is the lock design. Yes, I know, Chris Reeve came up with the design, from the liner lock by Michael Walker, based on the old brass leaf lock used on whaler, navy and electricians knives since around the turn of the century. In my opinion, Benchmade does it one better than any other design I have seen by using a radius at the heel of the blade instead of a flat cut. Without going into the design details of why this is better, suffice it to say, it is easier to use and, if done properly, adds more potential surface area for lock engagement. I have used or owned many framelock style folders and I believe the Benchmade design is the best.
What I don’t like about this particular model is the design of the recurve. I don’t mind recurve blades as such, but on this one, the end of the recurve at the heel of the blade is in the same place as your thumb when releasing the lock and closing the blade. It ends up hitting your thumb nail when closing the blade if you don’t remove your thumb from the lock bar. I think it could be improved by removing the last ¼” of edge and adding a choil in its place. On a knife of this size a choil could be useful and remove that drawback. The other item that I believe is improved on newer models is the clearance between the blade and the last standoff. When I received the knife it had two small chips in the blade toward the point. I have seen a number of posts complaining that the blade hits the standoff when closed. On this model it doesn’t actually hit the standoff, even when applying pressure to the back of the blade. What happens is that if the knife is tapped on its side, such as if you were to rap the side of the handle on a table with the blade closed, the inertia of the blade causes it to hit the radiused part of the stand off. This could easily happen during shipment or if the knife is dropped. Again, easily corrected by not allowing the blade to close quite so far.
One other item that I think would benefit this knife (and most framelocks) is the Hinderer Lock Stabilizer. It would eliminate the possibility of overstressing the lock when releasing it and also support the lock bar in the vertical direction.
I may end up having to purchase the 635, the Skirmishes smaller brother as I really am fond of this model, but don’t need a knife with a 4.3” blade that folds.
I will have the knife for a few more days before sending it on to the next person in this pass around, so if you have any questions, please post them and I will do my best to provide a satisfactory answer. Thank you.
Q
Awesome review, especially regarding the stand offs. Good job. I own that knife and agree with you on everything.
the skirmish that I've had for the past year and a half or so has nearly removed the end of my finger twice. The heavy blade has a lot of inertia behind it and if you don't for sure get it locked open, and give er a swing, then you might find yourself with the same bad luck as me.
I would prefer that the opening hole not be chamfered. It's too slick for consistent opening, unless you snap it open. Again with the heavy blade this could cause damage to the stop pin, but so far mine is still working pretty good. I tightened the pivot bolt up just to discourage me from snapping it open, and to be more careful in general when handling this bad boy.
I bought the knife because I wanted a portable trail clearing tool. It works amazingly well for that application, and the design of the handle allows for more reach. It is most likely, the best chopper of any folding knife ever produced! I've hacked through up to 2" fibrous plant stems with this knife and it just keeps on keeping on. It really does take and hold an edge very well, even under rigorous use. Flat sabre grind and relatively obtuse edge angle are super burly. Not a whittling knife.
I also wouldn't recommend this knife for regular knife use. It's way too big. It's probably designed for martial type uses, due to the name, but I would suggest that hikers, hunters, mountain bikers, landscapers, farmers etc would love this thing. It's a pretty specialized tool, and vegetable matter should rightly fear it.
Also, I've handled the mini version as well, and it is a totally different knife. Not as practical a design in a smaller size, in my opinion. The mini Dejavoo is a great Benchmade alternate.
I'm glad to see this review of one of my all time favorite knives.:thumbup:
Thanks man!
I'm with you on the Hinderer Lock Stabilizer.
I liked my Skirmish a lot and I still carry the little tyke every so often. My issue is the framelock in general, a lock design I've lost enthusiasm for.
Lorien, how is the small version "a totally different knife"? I have been toying with the idea of another knife for quite a while and overall like the 630, but have no need for a knife this large. I also have considered the smaller Dejavoo (745) as you mention. If you can expand on what you mean, I would be grateful as most of the knives we discuss are not available to be seen locally, so I end up buying from pictures and descriptions, which doesn't always work out so well. Thanks.
the strength of the skirmish design is partly in its size. When downsized, there is no power behind it, plus the flat sabre grind leaves a fairly obtuse edge for regular knife uses, or if you like a really keen edge. The chamfering of the opening hole which makes opening the 630 inconsistent, is even worse on the smaller model.
Finally, the drastic recurve is a pita to sharpen and doesn't provide any benefit to the standard knife user. The 635 is a beauty of a knife and feels great to hold onto, but its performance for regular knife work is compromised by it being designed after a knife which was designed to be big, if that makes any sense. If one has the money and likes to have things just because, well then the 635 is a nice thing to have.
The fully flat ground dejavoo, (or mini) has a wicked and easy to maintain and more usable edge, a thumb hole that has enough bite for consistent opening, and a liner lock which doesn't affect the feel of the knife. Which incidentally is very nice. The ergonomics of the dejavoo are surprisingly good.
You have a lot of point control with the dejavoo and much less with the 635.
Keep in mind that I am not a guy who considers the weapons applications of a knife, but who uses his knives pretty hard for many different types of cutting and chopping of things non human:).
For the record, my pocket knife is a 520.
Thanks Lorien.
As you, I use a knife for cutting purposes, not even as a chopper as I reside in an almost urban environment and don’t need a knife for outdoor purposes. I also don’t see a knife as a martial tool as in my mind, there are far better tools for that purpose. Thanks for your thoughts, I may reconsider the 635 for a 745.
i would get it i have them both and love them both if you have problems sharpening your knives get the spiderco tri sharpener its the best knife sharpener ive used but both my 630 and 635 are great knives there a poor mans sebbie
I'm another that has both, and enjoys them. Yes, they are cutters, not choppers, and as cutters or slicers, they do well.
FWIW, I should note that I have reprofiled both to a narrower angled edge, convexed and highly polished.
While I haven't used either as trail clearing tools, the recurve is awesome for trimming plants around the garden! :thumbup:
i've had two of these, my only complaints were the lock sometimes got stuck when I would flip it open with force, and the blade profile is not the greatest for stabbing. Everything else about the knife is spot on, it kicks ass. I sold my regular 630 and upgraded to the limited edition MOTENG 630BK-503 black blade, black handle, it is the sh*t.
Nice review.
The one thing I'd like to change is the clip.
I prefer tip-up.
I mean, I REALLY prefer tip-up.
This one thing keeps me from EDC'ing it most of the time. It is a great user knife, just that whole tip-down thing bugs me.
That's the reason the Manix and Rukus see a whole lot more pocket time than the Skirmish.
Nice review.
I prefer tip-up.
I prefer tip-down.
I mean, I REALLY prefer tip-down.
That is a prime reason why I EDC it most of the time. It is a great user knife, the whole tip-down thing makes it perfect for me.
:D
Seriously, I carry IWB, and tip-down just works a lot better for me in deploying. I also like the fact that it has a good chunk of metal sticking up above the clip, which makes it easy to grab for IWB.
I have recently acquired the skirmishes little brother. I have no complaints about it except i am a bit unsure about the framelock. When i grip the knife after it has locked into
position i can feel the lock slide further in a little bit. Is this common, or would this be considered a problem?
