Best option right now is the upcoming KnifeWorks exclusive Contego 810-1401 with an uncoated M390 blade steel for only $17 more than the regular Contego!
I wonder if they will put out one with a green or red blended handle?
But will the Satin Cerakote Coated Plain Blade show scratches and wear just as much?
The M4 is great stuff. I like it better than the D2. It is the coating on the M4 that is the problem. As far as rust goes I could not really say. The basic care I use prevents rust on all the non-stainless steels I own.
Do you hose down your knives with WD40? I have done that to a few after checking with the manufacture first![]()
Someone took their 810 blade in recent weeks and removed the coating, and the blade looked really great! With the new M390 version coming, that will solve a lot of problems. I understand M4 needs protection, but why is the Cerakote so fragile?
Thanks,
I read where WD40 is basically fish oil. So it should do a pretty good job of cleaning some things.
Especially where you can't get to without taking the knife apart.
Thanks Again
Joe,
I wouldn't say that CPM-M4 needs to be coated. I have a couple folders in that steel both with a nice satin finish, polished to some extent. There is no indication of rust on them and they have been used. It might be a measure used to calm and quell the misinformed concerned that some folks have about it being a rust magnet; as well as make the knife overall more maintenance free across the board. It will rust of course, but in my own experience it would have to be pretty well neglected. I've had O-1 tool steel rust more readily than CPM-M4, under the exact same conditions. In any case, some degree of maintenance should be taken to any tools a person uses. As for the Cerakote being fragile, I have no idea. It might have adhered better if the steel had a blasted/porous finish rather than a standard satin like finish. Hard to say, but I've seen it flake off of treated ARs & guns without much direct abrasion. I much prefer a well done DLC coating to any of the Cerakote finishes. One other thing to note, due to medication, environmental factors, and I guess genetics some folks have very acidic body chemistry. They can oxidixe just about any metal with the oils left behind by their hands. We've read threads about this on here, members managed to corrode stop pins, liners, and in some cases the handle screws pretty good simply by means of pocket sweat.
If anyone uses a knife for eating food, I would steer far and clear from anything like WD-40, which is a solvent and can't be good for our digestion. If there's a need I use food-grade mineral oil as a protectant and/or nothing at all.
